3g brake set up on a 2g!!
3g brakes are the same as 2g. Single piston calipers/rotors are identical and the dual piston calipers/rotors are the same.
The only difference is the the mounting brackets for 3g have bigger distance between the mounting holes than the 2g brackets.
Rear brakes are the same - disc and drum brakes are identical for 2g and 3g.
The only upgrade from 3g is the brake master cylinder and brake booster for some models.
