33* at steady throttle
justin0469
1,004
10
Apr 4, 2003
san diego, California
I have 720cc injectors, 50trim, 255 pump, aeromotive afpr, adjustable cam gears built 6bolt. At steady throttle past 3k my timing reads to be steady 33*. if i accellerate or decellerate, timing drops. at idle timing ranges from 4-9 after adjusting it -2* with my ecu+. isnt 33* a bt much?
at light throttle no its not to much at all. I usually get around that cruising on the freeway in my 93 AWD. Just be sure it comes down quick when you get into the gas and you have no knock during the transition into spool.
