30psi: terrible performance - 130hp??
cjridert1
403
6
Jul 4, 2007
Akron, Ohio
Just did rear bushings, driveshaft universals. Car was giving me drop off power fits just as I parked it for the bushings.
Car feels like something in the drivetrain is going on or is carrying 600lb more than normal.
Car sounds like its running fast, feels like Im driving a cutlas cierra.
Any ideas? I just pulled the clutch assembly - looks fine. Fluids look good in rear and trans.
Im guessing something goofy I missed, but not sure what it is
Hope that 130 was on a track.
Not only are you a post whore but you can't read. Try adding something at least remotely helpful when you reply?
@cjridert1 - I can't see anything glaring in the pull, it looks like you flow about ~53.1 lbs at 30 PSI. AFRs look good, no knock, temps are good... It looks like everything on the engine side is solid.
Does it still coast easily? Huge boost leak? Mess with base timing? Everything looks alright at first glance for the log, although the timing and fuel sliders are a bit alarming
Unrelated but related I guess, what program are you guys using to view the log. I cannot get the log viewable
Just put a new clutch in, rechecked all bolts/nuts in the rear, pulled the drivetrain, checked the universals again, whatever - car still runs runs terrible - any ideas? Im out of ideas...
Getting spark on all cylinders? It might be missing.
exhaust? I had a buddy with a civic where the cat broke and clogged the exhaust. He got all the sound of v-tec with even less of the performance. Everything sounded good, just no pull (well, less than normal anyways ;) )
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
