Yamadaaaa009
- 50
- 16
- Mar 7, 2023
Asia
Was trying to remove and change the steering wheel the previous owner installed and saw this 3 bolt adapter. Searched around and I think they're called Grant? I couldn't pull them out and I noticed that the bolt in the center is just a simple bolt and the hub they used was held on by the 3 bolts and a nut for the middle. I've honestly never seen this before and have no idea to remove them. I bought the usual hub adapter with splines and I'm met with a bolt and nut. Is there a way to change/remove this or should I just buy a hub adapter for this grant?
. I dont have a puller so I tried your suggestion but no luck. It's too tough, I tried smacking both sides of the steering wheel, rocked it back and forth but it won't budge. Tried spraying penetrating oil but still no luck... Will try again tomorrow and if all else fails I might have to borrow a puller by then. Thank you!
