Universal Steering Wheel Adapter Hub?
As long as the steering wheel your looking at has a 6 bolt that hub should work fine.
FYI though, I have one of these Ebay wheels on my car and personally I'm not a fan.
But, to everyone their own...
Good luck Pics If you decide to buy it
DSMs kept the same steering shaft spline spec all the way through production. However, you'll find that the aftermarket companies cut-off compatibility in their application charts in '95, when airbags found their way to steering wheels. Lawyers.
I use a grant hub and a grant wheel and have no problems at all! I also know some guys using the NRG hub and they love it!
Grant doesn't use a "standard" steering wheel bolt pattern. If you like any of their wheels, you're set. But you can't easily mount another company's wheel on a Grant hub.
anyone know if you can add a spacer behind the factory steering wheel to make it a little closer to the driver?
I am wanting to keep the airbag but still either lift the wheel higher or go with a smaller wheel. The only issue with the smaller wheel is that I dont get my airbags :(
any ideas?
Im really tall and this would help greatly :)
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
