3 bolt locked up, found one at junk yard for $60. rear cover said B1
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
my 3 bolt recently locked up on me, need to get a new one asap, was looking into 4 bolt rears but none locally and cant find any around as of now that are willing to ship and get me a decent price. so i found and pulled a rear diff out of a 1990 eclipse awd but i noticed it looked different than mine, the left side axle had the same size shaft ( going into the diff ) as the right side, the one on my car had a smaller shaft on the left side and a bigger shaft on the right side. dunno what the cover labeled B1 means, will my axles work on this diff or do i need those axles off that diff too?
as long as it bolts in place you should be alright. What about the Transmissions? did you take an auto axle for your manual or vise versa? The only concern there would be gear ratio.
both manual trans. isnt there a difference between the limited slip rear end and non limited slip rear end ? i thought the axles from a limited slip wouldnt fit a non limited slip. i duno. so i guess it should work then?
Sounds like its a non lsd axle. You would need trade your pass side axle for a non lsd axle.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
