iceman21221
- 159
- 0
- Jul 21, 2005
Baltimore,
Maryland
sounds silly. but has anyone tried a 3.5 inch exhaust on the 1g or 2g TEL's. i tried searching but only thing out there is 3" and 2.5".
JayRolla said:People have ran 4" on our cars. I think they said 3" exhaust becomes restrictive over 600whp.
I am running 3.5inch piping on my car. and it is fine. I do agree with dsmunknown. You my have issues with clearence going to much bigger. If you are interested, you can contact a company called Raceparts Solutions. They sell everything that you need to make your own custom exhaust. they even sell V-band clamps that will allow you to take exhaust apart in sections. Ask for Darrin or John. The number is 561-375-6277.
The sound is alittle deeper than normal, but sounds really good. I am using stainless steel 3.5inch piping for downpipe, and 3.5inch aluminum for the rest of the exhaust. that is until i get to the muffler. By the way. I am using hks for my muffler.
MyÜberFastGSX;151133888 said:If you get a mandrell bent exhaust system, then 3" is more than enough. Unless you pan on making a whole lot of power.
If you're planning on doind a crushed bent exhaust, then you might want to look at 3.5"
Sorry to come in to the thread being a new person here, but reading on the different sizing for exhausts, do you guys recommend the 3.5?
I have a 91 TSi and currently the exhaust is just the downpipe and open pipe. (bought it that way) so as you can see, that needs to be fixed ASAP.
What would you guys recommend?
Right now all it has is the 16g small turbo, a BOV, data logger, ACT 2100 pressure plate & clutch, turbo timer, and Manley performance 35mm intake and 31.5mm exhaust valves, and Manley performace springs.
Thats basically everything, so I need an exhaust for it, so who best to ask then you guys
Thanks
~Michelle~
I'm thinking some internals need to be replaced before that.
Thanks for the information though Ill keep that in mind
91TSiChick said:Sorry to come in to the thread being a new person here, but reading on the different sizing for exhausts, do you guys recommend the 3.5?
Thanks
~Michelle~
Thanks for the help so far
