2nd o2 sensor(cat)
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
I ordered buschur 3" exhaust NO cat 3" DP and o2 dump now will i use that end o2 sensor by cat or just remove it, what do u guys do?
The o2 sensor screws in after the cat so if the exhaust has a place for it you can still screw it in.
I am actually about to install the same exact set up and was wondering the same thing. Can I just remove that second 02 sensor? How much of an effect does it have? Does using a S-AFC II have any effect on if i need it?
The only thing I have really heard is that the Check Engine light will stay on.. and frankly I think every car I have owned has that light on LOL. Will the ECU get confused and make the car run bad if it is not getting a reading from that Second 02 sensor by the Cat.. that is the question I am wondering. I know all of you guys cant have that o2 sensor in there running test pipes.. even if it is installed won't having no cat at all confuse it?
