2G 2gNT Reverse wiring?
Stizzydrew
193
74
Nov 11, 2021
Los Angles, California
I found a wire that not connected that’s in the rear. My reverse lights don’t work and I’m thinking maybe this can be why. But I don’t know where the switch connects to. Pls let me know if it’s for the reverse and if so where it connects to, thank you.
You can see in the picture
Unfortunately, not for the reverse lights; that one is for the original 6-disc changer.
I'm not exactly sure how the non-turbo, manual 2Gs get the reverse signal from the transmission, but have you verified the sensor at the transmission is good?
Oh I see that makes sense. It has a cheap aftermarket radio. Thank you. Oh and I haven’t yet because I don’t have someone to help me at the moment. I had made a mistake a got a new sensor off eBay but it was to big and I put it in … rookie mistake, j don’t know what it did but it chewed up the new one and it would let me change into 3-5 and R. When I put my old one on it shifted fine but still no reverse lights when I took it out and put it back in. I know you can press on it when it’s out to see if it works but I didn’t do that last time. Is there anywhere else I can just buy a new sensor that isn’t from eBay. You got any recommendations sites. Here are the photos of what happened with the sensors
Looks like you got a sensor for the Mitsubishi engine applications and not the 420A.
I'd try RockAuto.
