420A 2gNT Removing Axles Manual Trans?
Sorry for the late response but their is really nothing to it. Take the lower ball joint loose and the tierod in loose, then pop the axle nut off and you should be able to move the hub around enough to pull the axle off. Don't forget to loosen the intermediate shaft support(I think). Glad you got it just really typing this for future reference. Not that much different then any other axle removal.
