420A 2gNT help! limp mode
You didn't change the transmission? If you're getting "limp mode" then that means your transmission is not shifting past 2nd gear. You might want to make sure you didn't unhook any of the wires from your transmission, or that any of the wires didn't get ripped.
The most common cause to "limp mode" is when the shift solenoids go bad.
