2gnt ECU's 95/97 differences
pr0 said:
I got my s-afc 2 today. :cool: Anyway:
I have a 95 2gnt, this write up says its for the 97-99, will it still work? Are the ecu's the same?
http://www.2gnt.com/nuke/modules.php?name=Sections&op=viewarticle&artid=69
no they are very different. heres the 95 ecu harness pin list http://www.2gnt.com/www/corbin/95ECU.html
EDIT: as i was reading through it, it appears that most of the wire colors are the same. but the 95 only has 1 harness, instead of an upper and lower like the 96 +
Thanks GS, Hmm... from the looks of it, since the colours are pretty much the same I should be able to do it no problem. :thumb: Good stuff, looks like I'll be busy this weekend. :cool:
By the way GSGoinFast, did you install it yourself? (your's)
ya i did, it really wasnt hard at all. the hardes part was getting the grommet to fit in the hole in the fire wall LOL. but ya its pretty strait forward, all the listed ecu wires you just strip, and wrap the corresponding s-afc wire around it and solder them in with the exception of the MAP wire. that you must cut and connect one side to one s-afc wire and the other side to another. you shouldnt have any problems with it tho.
pr0 said:
Do I have to drill a hole through the firewall or is there already a hole I can use?
i just drilled a new one, that thing is like swiss cheese now LOL
