project_skyline
- 46
- 2
- Mar 31, 2007
Silt,
Colorado
A friend of mine who has a 95 gsx has a 6 bolt swapped into the car.
The car has no rpm signal coming to the gauge cluster. If i'm remembering correctly the cluster has a plug on the back that slides into the male end behind it. While the 1g's have a harness going into it.
When you do the swap is there anything that should be changed so that it still sees rpm signal or is it possible there is just a broken wire between the ecu and the cluster? OR does it get rpm signal directly from the engine?
