2g Wheels and Tires Size Questions [merged] fit fitment
The tire width should be the same as your rim width for best performance. Run wider tires for a more comftorable ride but worse performance.
My 95 came with 225s on it (Fuldas). They cleared the upper suspension by just a little bit, but they did clear- no sign of rubbing. I went to 205 Yokohamas to replace them (AVS 100s were on closeout at $60 each), and the car felt a _lot_ more nimble and steered a lot lighter. Used those up, and am now back to stock Dunlops at 215.
My cars lowered and Im running a 215/35R/18 and have no trouble. Its a Kumho ECSTA Supra. Its a low pro tire though.
going too wide is not good in the rain though...i run 215/45 zr 17s
but it doesnt rain too much in Florida huh?:thumb:
ok i got some velox rims. no tires though. the rims are 17 x 7.5 how much if any wider can i oversize the tire, 205's are surpose to go on them but can i go wider? and if so how wide? I want more traction.
thanks
You should be able to run a 215/45 without a problem. That's what I have on my 17 X 7.5s
You can likely go to 225s or even wider. Do you know the offset?
I am not sure, but you can check the stock tiresize (which should give you the stock wheel size) by checking on the inside driver's side door panel.
Regards,
CMF
Just got some new wheels for my 97 Eclipse Gs-T. Some gunmetal 18" Motegi MR7s.. Got em at a good deal. Now, I need to buy some tires. What kind of tires would be good for these? The following measurements of the rims are 18x7.5 +45mm offset. I want a low profile tires but not TOOOO low to where im bending the rim on potholes. I want little tire but how much is too little?
err 40-series WAY too small for 18's you will feel EVERY bump 45-series will be more adaquate for everyday driving
i recommend 235/45/18. I dont listen to tire rack recommendations they said if u get 17X8 i should get 225:thumbdown
235/45/18 is def. not low profile IMO
i have 235/45/17 and they look horrendous [ wheelmax ####ed up ] i have gobs of traction but they make my wheels look smaller
for 18's i'd go 245/40/18 ; had them on my 3000GT and they looked great
I don't think you can fit 235/40/18's with 45mm offset unless you plan to use spacers.
That's what I was thinking.
225/40/18 would be the best fit. It would also be as close to stock rotation as you can get.
Here's the tire calculator.
http://www.miata.net/garage/tirecalc.html
Here's some different tires in that size. I just got the Yokohama ES 100's. I really like them so far. It hasn't rained yet though.
http://www.discounttiredirect.com/direct/findTireProductsBySize.do
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
