2G TSi Stock Boost Gauge Reading?
The factory boost gauge is simulated from various other sensors like the reading from the MAS, TPS, and engine RPM. If those signals are accurate it should be displaying vacuum while idling. Since it's not one or more of them is incorrect confusing the ECU and possibly causing the rough idle.
Could be either or both. Run a boost leak test and you'll have your answer.
