Resolved 2G transmission mount bolts
iheartguns
70
Dec 25, 2012
Colorado spring, Colorado
When i was taking off the passenger side tranny mount i noticed that 2 of the bolts coming from the transmission into to mount had really bad threads that wouldnt even catch anymore. My question is, is there a way to change these out and does anyone know the product numbers?
Solution
The two studs that come from the transmission to and through the mount are MD751929 and MD744661. The two bolts that mount the plate (with the other studs) to the transmission are MF241309.
Solution
when I just did my clutch I noticed there was two bolts from the tranny to the mount, didnt know they both had studs instead??? the studs can just be pressed back in??? one of my bolts in there are nice and tight, the othere is stripped, only one bolt right now..
Probably because you have a 1G and the original poster has a 2G. Two bolts is correct for your application.
