2g tranny on 1g block
slow4G63
102
Jan 14, 2005
Huber Heights, Ohio
so i was about to drop my built motor into my car finally but ran into a problem... :sosad:
my setup:
1g block (4g63), 2g tranny (from my 97 gst, 4g63)
after I put the 6 bolt flywheel on and bolted up the pressure plate I put on the tranny but noticed there were 2 gaps where you could see the flywheel
does there need to be some metal plates covering them?
1 of the holes is on the opposite side of the starter, the other one is on the bottom.
is something wrong? or what is the part called that i need??
thanks!
the one on the bottom is normal. thats the inspection cover and theres a plate to go over it. the one opposite the starter should be covered by the spacer/starter bracket/shim that goes inbetween the block and trans. not sure if this is what you did but you need to use the 2g spacer not the 1g.
ty! hopefully today i'll check it out
