2g tranny issues
eastace6
96
Nov 9, 2010
wichita, Kansas
ok im haveing a hard time getting into 2nd 3rd and reverse and it didnt start till i put my b&m short throw. went to my local tuner shop and they said my short throw is prob causing that. would like to know if its true or if hes just feeding me bull cuase im hoping i dont need to replace my clutch
It's possible it could be the short throw shifter. I have a b&m short throw shifter and if installed properly you should not have any problems, B&M has a good name for quality parts. Is there a chance you damaged your shifter cables? Try putting your old shifter back in see if the problem goes away.
I'd double check and make sure your master cylinder and slave cylinder aren't acting up. I had clutch issues in the past and difficulties shifting into certain gears, saw that the master cylinder was going out and just ended up replacing everything.
good luck!
