2g timing map ok to use for testing on a GVR-4?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
As you probably know, I have a boost fade problem and want to see if I could use a 2g timing map in my 91 GVR4 since it has a less agressive timing curve.
I plan to run 22 psi at 10.8 AFR for a short period of time. If so, which load tables and RPM tables (I think that is what they are called) should be modified?
The upper ones? I am not trying to tune using this method just see if the boost fade goes away.
I am using RT Tuner PRO with Ostrich
Thanks!
Worked just fine FYI.
