Is this MAP source ok?
Nate355RS
446
52
Oct 25, 2012
Salem, Virginia
My plan is to use the P port off the throttle body and T it off into the fuel pressure solenoid and boost gauge. Then use the B port as the source for my MAP sensor.
This would probably work well for the MAP, but would this be a problem for my AFPR, fuel pressure solenoid, or boost gauge?
attachment.php
I appreciate the links, but neither address my question.
The setup I'm talking about is identical to the pic above, except the B port would not go to the FP solenoid, but go directly to the MAP.
Im in the process of getting my map and haven't gotten to that yet
where else can you source it from, or other options?
I personally would not trust a throttle body source for the MAP sensor. It needs a clean, strong, dedicated signal straight from the intake manifold. You can see in this link how I installed my MAP sensor when I was running a 1g intake manifold. If you don't have a direct thread sensor like I did, you can always put a hose barb and run a very short section of vacuum line between the two. The shorter the better.
http://www.dsmlink.com/wiki/sdhose?s
I kind of feel like I'm in the twilight zone.
I respect the knowledge you have, but I don't think my post is being read. What I'm talking about would give the MAP a dedicated source straight from the IM.
The FP solenoid and boost gauge would get their source completely from the TB emission port
I may have misread it, but as long as you have a dedicated source straight from the manifold, you'll be fine.
The solenoid getting a source from the throttle body would be ok, as it's not a crucial part. As for the boost gauge, you'd have to evaluate if it reads properly and consistently all the time to see if your source is stable enough.
I don't know if I'd trust an AFPR off the throttle body though. It's a more crucial part that needs a good source.
That's what I was thinking too. The AFPR would be hooked to the fuel pressure solenoid and the solenoid would be hooked to the TB nipple and the boost gauge. I guess the real question is if the fuel pressure solenoid will work right if it's being fed from the TB.
