1G Source on intake manifold for GM MAP sensor
illeagle92
55
4
Nov 1, 2013
Farmington, New Hampshire
Hi there.
Having trouble finding a vacuum source for my GM map sensor. I know it's best to keep it higher on the manifold and as close to it as possible - but what do I use as a vac. source?
I've seen a few folks say to just mount it to the firewall and run a hose from the manifold to the sensor... but where on the manifold? Can I use one of the nipples on top by the tb?
Basically do I have to go get the manifold tapped and a fitting welded in or am I completely missing another way of doing this?
Thanks in advance. Sorry for the ignorance. I've been looking around but I want to be sure before I go pick up another manifold and pay for the welding/work.
Theres a spot on back on intake manifold that you can drill and tap to install the map sensor. Theres a thread somewhere on here about it. Do a search. Should be able to find it
