2g talon missfire while driving
lilsam
145
Sep 28, 2011
Milwaukee, Wisconsin
Hey guys i have a 95 eagle talon awd with a 6 bolt swap. The car has a chipped ecu for e85. The car has 1150cc injectors, garrett 3067r if that has anything to do with it. But getting to the problem the car starts up and runs fine, but when i drive the car i will just be cruising around and the car will start to run on two cylinders and sound like a Subaru. So i push the clutch in and car dies, let the clutch out and the car will go back to running fine until it happens again. i have flipped the cas sensor to see if that helps, but it didn't seem to do anything. any suggestions?
Infamous p0300 random misfire code? Im thinking so. Swap to a 1gb black top hall effect cas to cure your problem. That, or get ecmlink and disable the misfire code so it can still run the green top 1ga optical cas. ( 2g ecu dont like optical).
The black top cas won't always fix the random misfire problem The best thing i've found that works is the 10k potentiometer mod.
    • george bromwell
    • pma1123
    • Sdcryan1
