2G Suttering while driving. (Sometimes)
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
On the last drive I took my car on I had a weird issue. I would let off the gas to coast, then get back on it. The car hesitated and sputtered, so I let off the gas and then I got back on it and it was fine...? It only did that one time during the 5 mile drive.
I haven't driven it since. It blew a coolant line on that drive.:ohdamn: I am in the process of redoing the entire cooling system (new silicone hoses, cleaning out the rad and t-stat housing, new water pump). I will tighten up all of my clamps again.
I know turbo to IC is good. I have the stock upper IC pipes on right now, so if I had a leak it would be above the IC and before the throttle body
Sounds like your going to be busy.LOL I just finely got everything back together on my car. woohoo! Not sure if you know you can make a boost leak tester for cheap.
