Resolved 2G Switched 12v sources
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I am installing an AEM 30-5132 boost gauge, and it requires a switched 12v source. The catch is that this source cannot intermittently turn off when the key is turned from accessories (ACC) to on to start. The gauge zero's out (auto-corrects) when the key is first turned to ACC, and subsequent power losses cause it to remain zeroed and to not function correctly. I tried using the cigarette lighter source, but I have to assume it loses power while the key is being turned from ACC to on (or to start), because it doesn't work.
I've tested most of the fuses in the kick panel and none of them are what I'm looking for. (I just had surgery on my shoulder, so I gave up before testing them all). Can someone tell me any and/or all sources that are switched?
Thanks
Solution
Battery = unswitched
IG1 = Start, Run and Accessory
IG2 = Run and Accessory
ACC = Run and Accessory
ST = Start
2GA Multi-Purpose Fuses
ST = Start
Solution
