2g Spyder Roll cage
Well what kind of cage you need is going to depend on what the drag track requires for the times you run or the road race club requires for your class.
So which do you need?
Umm 1 that fits my car. I dont think it matters at the moment, especially since I havent found a track yet, just moved here. But regardless I still havent found someone that will make one yet. Was just hoping some other spyder owner knew a guy
The reason I ask is because you want to build one to the specs that will meet the requirements. If you dont, youll have a hell of a time cutting it out to put another one in.
Any really good roll cage/system will probably turn your car into a roadster. In other words, you'd probably have to remove the rear seat to mount the cage directly to the frame.
I know the rear seat is practically useless, but it's food for thought.
  • Wanted 6 bolt NT water pipe
    • chrisman287
