Resolved 2G oil filter housing
wises4057
143
Mar 28, 2005
Wisconsin Rapids, Wisconsin
Alright guys and gals. I have a problem. I need to find an oil filter housing for my car. I got a 97 eclipse GST. It cracked around the oil pressure sending unit and spewing oil out. how do you change those, I can't find it in my repair manual anywhere, and what price are they?? where can I get them from.
Ok thanks. Do you think I'll be ok with a gasket from the local auto store?
Good luck finding it an auto parts store. My local ones do not carry it indivdually because it comes with the oil pump gasket set. I ordered one from extreme psi for around $4.
That is a correct statement. Just called everywhere and no one has it. Jnz tuning or local Mitsubishi here I come. Is there a difference between the 1g 7 bolt and 2g 7 bolt OFH or do they just use the same gasket?(md185528)
You can buy the whole front case gasket set for like 10 bucks from your local parts store that will have the ofh gasket. The part number is, TCS45941 and that is a felpro part number. They should have it in stock, and if not most can usually have it the next day.
Grab an evo 9 ofh and then add an external oil cooler
