2g OBX gauge cluster
KDub
97
Nov 3, 2006
Mesa, Arizona
i just received the dual gauge pods for the gauges bezel seen here here
It came pretty quick and looked nice. So I pulled out the stock one like the directions said and went to fit in the new gauge bezel. The problem is that it seems too small vertically. I compared it with the stock one and it fits perfectly in there but you cant put the stock one in there because the gauge will hit the stock bezel. Also the plastic window is in the way when i put the gauge in so it stick out a little bit. Anyone else have this pod too? Wondering is the autometer one is a better fitment. Wondering if obx made the piece wrong or am I doing something wrong?
I got one from GlowShift. Same problem. The gauge hit the stock bezel behind it. Someone didn't think that through. When I called GlowShift they told me that to use that piece I'd have to remove or modify the stock bezel behind it. I decided I didn't want to cut up the stock piece because it would look terrible so I sent it back and exchanged it with 2 swivel pods.
My advice to you is do the same if you can. Either that or cut up your stock piece behind it.
Tom
I have a non-OBX and don't have any of the fitment issues as far as cluster install. However, the longer gauges such as the autometer EGT (which has long plugs comming off the back) will stick out a bit, but it's not really noticeable. My boost gauge, however fits perfectly.
with one do you have? i dont have any fittings on the back. its just an electric oil pressure gauge. so im pretty sure if that doesnt fit nothing else will. i like how this would look if it fits correctly. just making sure im not missing something.
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
