2g nt wierd temp rise
750_sport
70
Feb 17, 2005
Sacramento, California
2g N/T
Car just rolled 90k miles.
Car ran low on oil still was at half full.
Did a oil change, small brass flakes in oil. Not a lot and not very big, You could see them pouring the oil out shining a flashlight through it.
Now
3rd or 4th gear pulls are fine
take off in 1st and run it out to 5k rpm and temp gauge rises. Then it will rise with throttle
and go back down with throttle, almost at the same time.
I bled the cooling system at first before hand I had small bubbles and idle. I then topped it off and let it idle for 15 min with the heater on then topped it off again. add cap
Same thing happen again
Comp numbers are 205, 210, 210, 185
Spark plugs looked great, Nice tan color.
This has never happen before, and the car never got to 3/4 on the temp gauge.
I'm stumped. No tapping or knocking noises....
Was thinking about pulling the pan off and swapping out crank and rod bearing, maybe a headgasket as well....
Well had to tow car home lastnight
On the way to work at idle car started missing.
Didnt risk anything, No over heat, Temp gauge in middle or just below.
I get it home and with a comp gauge I'm getting 210 207 211 210
Car just rolled 90041 miles
I give up!
Looks like maybe a blown headgasket, coolent was low and the plugs had a very faint light green color on the tip.
So maybe a headgasket and a pull the oil pan inspection.
In the mean time I now have to drop the motor in my MR2 and drive it around.
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
