Resolved 2G No power to PTU
v8s_are_slow
2,824
280
Sep 30, 2002
Panama City, Florida
Replaced engine and then was only running on 2 cylinders on first start. Trying to diagnose and now for some reason, no power to the PTU at all. PTU has been tested and is good. Just no power going to it. Checked fuses under the hood. Fuel goes to the rail though so assuming MPI isn't the issue.
Where does the power wire go to on the other side of the harness so I can check for continuity? Thanks!
Solution
The one wire that got replaced due to being a bit too toasty in an engine fire a few years ago fixed my issue. Just have to button everything up now. Shew!!!
Guess this post can be closed up now. Thanks y'all.
Yeah, everything else is getting power. But not sure if the noid light isn't flashing when I spin the cas housing because it needs the crank as well.
I guess if I put it all back together again and it doesn't work, it's back to the drawing board. 🤞
