2G motor swap questions...Oil Squirters!!!!
Lilbloody4
85
Feb 14, 2010
Schweinfurt, Europe
Alright I found an eclipse with a 6Bolt and I figured that I'd use the block and keep my 2G head, change the exhaust cam to the 1G, use 1G Throttle Body, 1G upper and lower radiator hoses, CAS from 1G, and the Intake Manifold from the 1G... OK, from my recent research info, I found out that I can't use my block because it was a N/T 6Bolt... Is it true that they dont have the oil squirters like the 2G, if so what is it that I can do to make this block work for me????:confused:
The 1g turbo blocks have the piston oil squirters also the N/T do not, but the block are the same other than that. The squirters just keep the pistons alittle cooler by spraying oil on the back of the piston. Swap the pistons from a turbo block (rods are the same) into the N/T block and it will work just as well as the turbo block.
