2g mas problems
boostcrazy92tsi
125
Aug 3, 2003
alright so over the winter i put in a set of 550 injectors and a 2g mas. when i first got the car out the fuel trims were pretty good. i was taking a little fuel out and keeping them balanced. lately this has not been the case. ive been adding fuel every day and my trims keep goin higher. the high trim is the worst its almost maxed out at +2 at 2000 and 3000 rpm. Also wot pulls at 17-18psi suck. im gettin like 3-10 counts of knock. ive added fuel and pulled it away yet nothing happens. ive boostleaked about 4 times now and on the last 2 ive found nothing. also my safc is reading a max of 1770 hertz and on my 1g mas i was pulling over 2000 hertz. any input would def help!! :talon:
im running 44psi base and the pump is out of a stealth TT. im goin to pull the injectors and swiith back to the 450s. if the problem cleans up than the used injectors i got are dirty and ill have to send them out to be cleaned.
When was the last time you replaced the fuel filter? That would be the first thing I would check. Next to make should your fuel pressure is rising 1:1 with boost.
-Brian
