2g manifold pressure sensor on 1g engine
justin0469
1,004
10
Apr 4, 2003
san diego, California
so im gettin a CEL for code P1400 - manifold differential pressure sensor because i have a 6bolt swap and the 2g sensor has no place to plug in on the 1g manifold. where can i hook this up so that im not gettin a CEL and running lean?
I also have a 6 bolt in my 97......... just have to modify your intake........ all I did was drill a hole in the end of it, (the small flat side near the brake fluid and FPR) screw it in, and no problems what so ever. Too bad I am in Iraq cause I am getting rid of that sensor and also that intake would be an easy fix for ya. But I did that with my stock ECU initialy and also DSMLink.
there are a few people making mdp adaptors - (ya bolt your sensor to the adaptor and shove a vacume line on the barbed fitting )
