Resolved 2g MAF on a 1g?
szewczyd
792
Aug 31, 2003
Oconomowoc, Wisconsin
i looked on vfaq and the installation seems rather simple. I noticed that they said you should run 550's or a SAFC. Do I need a SAFC and 550's to use the 2g maf. Is installing a 2g maf really worth it and how easy is it to actually do?
You do not have to swap injectors if you have a SAFC.
A couple benefits:
1) A 2G MAF is less likely to be overrun by high boost levels, where a 1G MAF would. It is capable of measuring more air before the signal it sends to the ECU starts to degrade.
2) 2G MAFs are larger than the 1Gs, so they are less restrictive on the intake side. This benefit is negligible IMHO, but hey, every bit helps.
If you put in 550's at the same time you install a 2G MAF, you might be able to get away with no SAFC if you have a logger to watch things and make sure nothing bad is going on.
I would not advise using the 2g maf without an AFC.
You'll run a pretty good deal lean.
I was once told that 550's and a 2g MAF are a wash, but i was told by a more informed member that the 2g's MAF readings vary quite a bit, so you'll definitely need an AFC to get the best out of it.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
