2g Head Build - Where do I start & what do to.
GofaST4life
2,897
132
Oct 21, 2007
Medina 44256, Ohio
Whats up guys.
I recently picked up a complete, partially torn down 2g head for an absolute steal of a price.
My idea was to do a stock and or mild build in my spare time. I have never worked on something like this before, so im very excited to get my hands dirty in some actual engine/head building.
Some of my initial questions:
1. Before I even start to work on it, is there anything I should do/check/measure?
2. Is there a specific cleaner I should use to do an initial clean of the head? Or would a strong degreaser like Simple Green or Purple Power be okay?
3. Keeping the stock and/or mild build idea, what stock parts should I reuse, what parts should I look at upgrading?
4. Is there a "Write Up" or suggested build path for something like this?
Please keep in mind, I don't want to go big/expensive and I would like to do all the work myself.
What suggestions do you guys have.
There is really nothing you can do here. You need to take it to a machine shop to get it checked and machined if needed for straightness of the bottom of the head and pressure check it for leaking valves.
The machine shop will clean the head for you while machining it.
With a used head it is always a good idea to replace the springs due to age. There are lots of inexpensive aftermarket options out there the machine shop would be willing to install during reassembly I am sure. It would be a good idea to upgrade the lifters to the 3mm port ones and have a valve job done on the head.
Every car is different and it depends on your individual goals and what you want to do with the cars.
To do it right and make sure everything is in good shape this really isn't much of a possibility unless you have the proper equipment. Getting the head machined and checked can be under $100 and you can install the springs yourself if no valve work is needed.
With something like a cylinder head that has such specific clearances, this is something you want a professional to check.
I WOULD AGREE WITH 95blackGsTurbo TAKE IT TO A SHOP AND HAVE THEM MEASURE AND CRACK CHECK IT I WOULD HAVE THE SHOP CHECK FOR ANY BAD GUIDES IF NONE OF THEM ARE BAD THEN YOU SHOULD BE ABLE TO USE WHATEVER VALVE YOU WANT AS FAR AS THE SEALS I WOULD SAY A SET OF VITON AND AS FOR SPRINGS THAT DEPENDS ON WHAT CAMS YOU PLAN ON RUNNING AND I WOULD ALWAYS SAY A GOOD PORT AND POLISH JOB TO HELP WITH POWER AND PERFORMANCE.
BogusSVO, yes the head came with the cam caps. It was complete with minor disassemble.
THANK YOU guys for the links and information.
Ill be sure to keep this thread updated as the build starts.
If the valves and springs are still installed in the head, first thing to do is fluid test the head.
This will give you a quick way to tell if the valves are bent, or if the head is severely warped.
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
