Resolved 2G GSX to GST ECU swap
Solution
i think there might be something wrong with my ECU.my friend has a 98 gsx and i have a 99 gst and i was going to use his to see if my car will start
You will not have to do anything then. Just swap his ECU in your car and you will be able to tell if your ECU is good/bad or if it is something else.
Is your CEL coming on when you turn the key to the ON position and is the boost gauge moving up to 0 and falling back down?
I'm curious to know this as well. Would you have to change anything with the Cam Angle Sensor wiring when switching from 95 to 98?
Solution
yea but my cam sensor is only getting 3.5 volts and its supposed to get 12 volts. so figured its could be the ecu.
    • Sdcryan1
