2g gsx rear sway bar
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
ok, I found a few threads on this, but still cant find the size of 2g gsx rear sway bar. Can someone help? I looked uo on-line and found that it was supposed to be 18mm, but I need a confirmation.
RM Racing, known for their work on the Acura NSX, has brought us these awesome sway bars, track-proven by the hard-driving RM Racing crew. The bars fit all 1995 or newer Eclipses and Talons. The RM Racing front bar is 20.6mm in diameter (40% stiffer than the stock 19mm). The rear bar is 80% stiffer than stock. For AWD cars, that means a 20.6mm bar instead of the stock 18mm; for FWD cars that came with a rear bar, the RM rear bar is 17.5mm instead of the stock 13mm.
Taken from this thread (yes, it's a vendor group buy thread, but it still has good info):
http://www.dsmtuners.com/forums/ven...racing-sway-bar-group-buy-popular-demand.html
I just swapped out my stock sway bars from my 2g 1995 talon tsi awd. The stock bar is 18mm I assume it fits in the 2g gsx? dunno but I have one in ok shape (a little rusty, and I had to grind the links off) I could wire brush and repaint, it would look great. Heres a side by side photo with the stock vs the rm bars
Did you install both? How does it feel? feels more understeer or oversteer?
Thank you
I installed both RMDSM bars at the same time, instead of the rear only. Still understeers, but much less than stock. I can get most of the remaining understeer out by altering tire pressure.
