2g gsx front caliper bracket different?
redline7
69
Jan 21, 2006
kissimmee, Florida
Hey couldn't get a straight answer from searching. I got a 2g gsx and I noticed that one of my front caliper brackets has a broken bolt. I could try to drill it out or just get another bracket. I need to know if the front caliper bracket on a gsx is the same as a gst or maybe a gs. Thanks
No they are not the same. The GSX uses the dual piston caliper and it's mounting bracket. The GST and GS use a single piston caliper and it's mounting bracket. They are different and not interchangeable.
You can order the bracket from O'reillys its an order item but they cost like 15-20 bucks
swade
ok thanks guys. I can just pick one up from advance auto for about $20. I figure I will change pads and rotors all around and I should be good.
