2g Fmic ?
Slippi84
4,454
20
Jun 8, 2005
Cinnaminson, New Jersey
Are the front frames the same for all 2g's in the sense that the openings are in the same place so that a fmic where the outlets go straight back threw the frame would fit a 2gnt liek they do a 2g 4g63 motor car?
I to am almost 100% sure as well. My buddies turbo talon looks exactly like mine so i would say yes. Same frame differant motor trans thats all
Yes, but obviously the engine, tranny and accessories are in different places, so be keep that in mind when planning your FMIC setup.
If you are asking about doing a custom job yourself, the pipes will not directly line up. Modifications may be necessary. I bought a 2gfmic kit and had to cut through the bumper and bend 2 of the pipes slightly.
The actual ic mounted right up with some custom brackets.
Try a universal pipe kit off ebay, cheap and effective.
