1G 2g DSMLink to NA 1g conversion harness
Carguyf545
Sep 2, 2014
Olympia, Washington
I have a 2g ECU with DSMLink out of a 95 GSX. I want to put that ECU in my 91 Eagle Talon with a N/A 4g63/4g64 motor. My research says I need a conversion harness. I can’t seem to find anything like this searching the internet.
Is there somebody in here that can make this harness for me? Preferably I need it before the 10th of June.
I called them. I was told they have never made a conversation harness. And they don’t modify n/a ECU’s.
I do have a couple of EPROM ECU’s that I think are N/A. Can I put a socket in the ECU and burn a chip with the moats burn 1? What software can I use.
If any one can shed light on my unique situation, it would be much appreciated
The ECU conversion harness from a 2G to a 1G ECU is quite involved and I'm not sure what you're going to gain in the process. DSM/ECULink isn't really intended for NA cars but with enough effort I'm sure you could tune one using it.
If the NA EPROM ECU's you speak of are for a 1G then I'd make sure thay are clean with their caps changed and use one of those with TunerPro and the correct NA XDF file to tune and make chips.
Can you point me in the right direction on how to use turner pro with my ecu? Is it as easy as installing a socket and burning a chip with a moates burn 1.
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
  • For sale 420A OEM 2G DSM 420a Fuel Injector Wire Harness
    $15 + shipping/fees PayPal, Zelle, Venmo, Apple pay
    • Stizzydrew
