*** 2G DSM Quaife quick rack Group buy 2026 ***
FIBA M - EC17PSE
Supporting Vendor
6,772
5,197
Nov 1, 2008
Orlando, Florida
2G DSM Quaife Manual Rack Group Buy (Quick Rack)
PLEASE read thoroughly — all key details and options are outlined below.
Since the original batch back in 2020, FIBA Motorsport has consistently had requests to bring these back. After a long wait, we’re opening the door one more time—but this only happens if the demand is there.
What is it?
This is a Quaife-engineered quick ratio manual rack conversion for the 2G DSM.
Faster steering response
Less steering wheel input for more wheel angle
A much more direct and connected driving feel
Think EVO-style steering response, but designed to work within the 2G DSM bolt-on housing—keeping things far more cost-effective and practical.
  • Key Specs
  • Ratio: 2.1 (OEM is 2.55)
  • Type: Full manual rack conversion
  • Manufactured by Quaife Engineering (UK) - Bought to life by FIBA Motorsport
  • Designed specifically for modified 2G DSM housings
  • This is about as close as you’ll get to EVO steering feel in a DSM.
*** Important – Manual Rack Considerations
These are now FULL manual racks.
Works great with smaller tire setups
With wider tires (235/245+), expect heavier steering at low speeds
Once moving, steering becomes much more manageable and responsive
If you want power assist, you will need to consider EPAS (Electric Power Steering).
EPAS Option (Power Steering Alternative)
Previously offered by Mr. Cole as a bolt-on kit for DSMs.
Estimated 2026 cost: $600–$700
Direct bolt-in + wiring solution
Note: We do NOT currently offer an EPAS conversion kit.
*** Rebuild & Machining Options
You will have two paths:
  • Option 1 – DIY / Local Build
Perform machining and rebuild locally
Each rack will include precise technical drawings
  • Option 2 – FIBA Motorsport Rebuild Service
We are now looking to offer a complete in-house/local solution:
  • Full strip-down
  • Precision bore machining on a CNC machine for the new pinion shaft
  • blasting + durable coating (steel components only) on the rack housing,
  • Alloy components left raw for OEM-style finish
  • Full reassembly, greasing, and spec tightening
Option 2 pricing TBC once we discuss with the machine shop.
*** Optional Upgrades
  • Block-off caps for unused hydraulic ports (Price TBD)
  • Billet Aluminum Pinion Housing, Replaces the heavy OEM steel unit, Reduces weight, Clean, simplified appearance and Black anodized finish fully bolt on with a new sealed bearing.
Available for both new and previous buyers (Price TBD)
Pricing (Estimated)
Rack & Pinion Kit: $632.50
Includes bulk shipping to Florida to us, duties, and insurance (at time of checking)
Does NOT include shipping to you (to be calculated later) as rack and pinion kit vs a full rebuild kit will vary on weight. insurance and value of course.
Note: Final pricing may vary depending on shipping/duties at time of order.
Critical Requirement
This group buy ONLY happens if we reach:
35 COMMITTED BUYERS
This is a strict requirement set by Quaife.
No exceptions.
Final Note
This will likely be the LAST attempt to run another batch of these racks.
We would love to be able to get them out to you all as we have plans to do the 1G DSM MANUAL ratio rack and pinions for Power steering housings after as we know the 1.8 Manual ratios are sought after! So the 1G DSM will get some new love to!
This is not a small project—it’s a major undertaking—but one that delivers a truly unique upgrade for the DSM platform.
We’ve done this before, and we’ll do everything possible to make it as smooth and accessible as we can.
Interested?
If you’re serious and want in:
Comment or message to be added to the pre-list
No commitment required yet—but this is how we gauge if the project moves forward.
Bummed I missed out on the original round. I'm in.
I hear you. I know the price and world has changed since back then. So prices have changed in every section. This is for sure a thing to not miss out on this time around
It seems improbable to me that there are 35 people willing to spend this much on such an old platform for a fairly niche upgrade, but I can hope! 😁
I have one of the racks from the original order and it is amazing. Anyone on the fence should jump on this one.
It is an event pulling the car in and out of the garage on 245 tires with no assist, but the feel and responsiveness of the rack after parking lot speed is 100% worth it. I modified my steering column to add the Prius power assist motor just before putting the car away for the winter and that was a game changer getting in and out of the garage.
Yeah It might be tricky. But currently I posted up the pricing and people know the deal. I have about 30 currently listed as interested so thats hopefully good news!
Thanks for the feedback. Mr Cole is in on this again for those wanting EPAS so will be great for those wanting some assistance. Glad you still love it and enjoy the feedback it offers you while driving 🤘
Working on the parts today to get an idea of a few things across the board!
* Seals and bearings will be a part of the rebuild from my service if opted for! This will cover the pinion side fully top mid and bottom! NOTE that the top bearing CANNOT be replaced on the OEM pinion housing as it is a custom bearing size! But the rest is fine to replace!
(IF you do not get a rebuild kit you will just receive the rack and pinion as a set only)
* The rebuild service from me will include all the steel hardware being acid cleaned and re-plated to an OEM spec! Basically you're get back what will look like a factory fresh rack to FIBA Motorsport standards!!!
* The lower old PS (power steering) ports on the steel shaft of the rack itself will be cut off and welded up as standard. This will smooth the rack and offer a nicer, cleaner look!
---OPTIONAL EXTRA parts... Are not required if not wanted and can be rebuilt still just fine!
These can be back used from the first batch of kits done in 2019/2020, so IF you have one of the first batches and would like these optinal items, then please do get in touch via PM, specifically asking for these items only!!!!! I can then add you to these on a separate list.
* Billet pinion housings will be offered up. ONLY they will allow a new upper bearing to be used due to the available off-the-shelf size, The rest is off the shelf anyway so it crosses over ok. These will be anodized black to match the OEM color. These will help shave a good bunch of weight!
* Another part being looked into that has not been done prior is the passenger side end cap and inner seals! These are normally a 2-piece steel system in stock form!
FIBA is looking into a 1-piece BILLET aluminum version to help shave some extra weight, and these use off-the-shelf seals. This will keep the same mounting design with the ring inside but help with some weight loss for an overall lighter rack system!
Currently My spare rack is disassembled and rack is now with the machine shop as they are going to work out the cost for the mounting jig and their part to machine the racks once they come into me for the rebuild service.
My end goal here is to offer the most comprehensive rebuild for you all to the most pleasing and highest spec in looks and performance and with new seals, they will be AS NEW as they was from the factory back in the day.
I already pinged the Facebook thread, BUT IM DOING IT HERE FOR RECORD LOL.
I have Power Steering deleted on my car with a welded center diff, it's really not terrible with normalish tires.
It'd be nice to get a little more assist and clean up the other PS lines. Hoping this takes off
Put me on the list as well please! I’ll add this the plethora of other suspension parts I need to put on once I take the car off the road again. Thanks for bringing this to market, Bobby!!
Josh
Got some way on the racks and progress of the machine work.
Should hopefully have the rest of the prices this week.
Working on bearings and the new ones will be sealed (metal) to help keep debris out and keep them self lubricated longer as the oem open type rely on grease and fluids. These will add a nice service life.
Note that the upper bearing cannot be replaced on the rebuild service if opting to use the stock metal pinion housing due to a custom bearing size not off the shelf.
So the Billet versions will be the only housing the uppers can be replaced for an off the shelf size
Lower bearing is changed in both options
IT IS NOW LIVE!!!!!!!!!!
Thank you for waiting, and while I worked to get all the puzzle pieces together, as it is a lot to work out and get arranged, from setting up, importing etc etc. To get this all inline is time-consuming but we finally have it ready to go live! https://fibamotorsport.com/product/2g-quaife-manual-steering-rack-group-buy-now-live-april-2026/
For those who want a refresh on their original setup, which we have been asked for by a few already, this is another service on the website specifically for you.
ANY manual rack can opt for this service! The same detail and service parts will be as the GB parts. This link is here for that https://fibamotorsport.com/product/2g-dsm-manual-rack-fiba-motorsport-service/
THANK YOU and hope we can get this through in 2026 and get another batch of these rare units out on the chassis.
What is it?
  • Key Specs
  • Full strip-down
Pricing (Estimated)
35 COMMITTED BUYERS
No exceptions.
Final Note
Interested?
If
What is it?
  • Key Specs
  • Full strip-down
Pricing (Estimated)
35 COMMITTED BUYERS
No exceptions.
Final Note
Interested?
Is this a direct bolt on with no modifications ?
Yes it will be. Once the rack has been rebuilt with machined bore the received kit will be fully bolt on ready for an alignment / setup.
If opting for EPAS from Cole then that will also be bolt on but you will need to do some wiring for the power and ground. That is about it.
This kit and rebuild service is and always was designed to make it as easy for the install as possible
Bobby, what's the latest on this?
Above says payment needs to be finished/paid off.
Below states that payment will NOT be taken up front?
Maybe a clash between when I had the initial post and the new one I re wrote. But NO payment is required till the spots are filled.
I shall edit this tonight to remove the wrong info.
Thank you for bringing this to my attention!
It is all fixed now dude. hopefully this is better and sorry for the confusion
Currently, we have around 20 confirmed orders!
Close, but we need the 35! HELP share and let's get everyone their racks many have been asking for since the first batch!
