2G 2g DSM Engine Bay Electrical Connections
This article is designed to help 2g owners identify all the plugs in the engine bay.
The photos and wire colors were based off of a 1999 Eclipse GSX, so other years and models may vary in location and wire color.
I would like to give a HUGE thanks to turbosax2 for helping with the photography and the documentation for the article!!
The way the tech article will be set up will be as follows:
This post will have the master list of all the connectors. Each connector will then have it's own separate post below which will contain a little description and a few pictures and diagrams. The first picture will be an overview shot to show the general location of the plug. The plug will be circled in green. The next picture will show the plug itself. Following that will be a picture of the back of the plug to show how the wires are inserted into the plug as well as wire color. And lastly will be a diagram showing the arrangement/layout of the wires as well as the wire colors. These diagrams will always be viewed when looking at the back of the plug with the clip (the part that holds the plug in) on the top.
Some descriptions will come from the service manual and others from Virtual Tour of the DSM Engine Bay - Quadrant map.
Master List
1. Manifold Differential Pressure (MDP) Sensor
2. Fuel Injector 1
3. Fuel Injector 2
4. Fuel Injector 3
5. Fuel Injector 4
6. Ignition Coil (Coil Pack)
7. Ignition Power Transistor
8. Throttle Position Sensor (TPS)
9. Knock Sensor
10. Camshaft Position Sensor
11. Auto-Cruise Control Vacuum Pump (Cruise Control Actuator)
12. Volume Airflow Sensor [Mass Airflow Sensor (MAS)]
13. Fuel Pressure Solenoid (FPS) Valve
14. Exhaust Gas Recirculation (EGR) Control Solenoid
15. Condenser Fan Motor [Air Conditioning (A/C) Fan]
16. Brake Fluid Level Switch
17. Radiator Fan Motor [Main Fan]
18. Hood Switch
19. Dual Pressure Switch (AC)
20. Capacitor (Noise Condenser)
21. Left Headlight
22. Left Combination Light (Parking)
23. Left Side Marker
24. Right Headlight
25. Right Combination Light (Parking)
26. Right Side Marker
27. Evaporative Purge Solenoid
28. Theft Alarm Horn
29. Idle Air Control Motor (ISC, IAC)
30. Turbocharger Waste Gate Solenoid Valve [Boost Control Solenoid (BCS)]
31. Back-up Light Switch
32. Front Wiring Harness and Control Wiring Harness Combination
33. Evaporative Purge Solenoid to ECU Harness Connector
34. Crankshaft Position Sensor (CPS)
35. EVAP Emission Purge Control Solenoid Valve
36. Air Conditioning (A/C) Compressor
37. Engine Coolant Temperature Gauge Unit
38. Engine Coolant Temperature Sensor
39. Heated Oxygen Sensor (Front O2 Sensor)
40. Starter Solenoid
41. Vehicle Speed Sensor (VSS)
42. Positive Battery Cable/Starter Motor
43. Left Fog Light
44. Right Fog Light
45. Generator (Alternator Power)
46. Generator (Alternator)
47. Power Steering Pressure Switch
48. Horn
49. Oil Pressure Switch (Dummy Light)
50. Oil Pressure Gauge Unit
51. Ignition Suppression Resistor (Fuel Injector Resistor Box)
52. Engine Speed Detection Connector
53. Windshield Wiper Motor
54. ABS Hydraulic Brake Unit
55. Left ABS Sensor
56. Right ABS Sensor
Wire Color Key
B = Black
Lg = Light green
Sb = Sky blue
V = Violet
O = Orange
Y = Yellow
Br = Brown
G = Green
Gr = Gray
L = Blue
P = Pink
R = Red
W = White
Here's an example on how to read the diagrams.
If you look at the picture, you'll notice there is 2 wires coming out the back of the connector. The diagram has 2 boxes that contain letters from the color code list above. The first box contains RSb. The first letter is the main wire color - red. The second letter (if applicable) deals with the stripe color, which in this case is sky blue as you can see in the picture. The second box contains a G for green. There is no stripe on this wire. These diagrams only deal with main wire color and stripe color. Some of the diagrams contain blank boxes which just means there is no wire there.
It's the starter solenoid connection to the main harness. Interestingly, it is what the four posts previous to yours are also discussing (i.e., the wiring diagram is shown in post #75).
Descriptions from the original post have been added to each of the individual posts.
Does anyone know what this relay is, it’s near the factory boost controller (passenger side). Sits behind the bumper I believe.
3 wire feed but it’s melted so I can’t really see what it is
I know this is an old write-up, but this is a god send.
I went to work on my engine bay today to connect some sensors and what not. It's been 3 years since I've seen that engine bay assembled, I had a hell of a time remembering what goes where, despite having color coded every sensor and its partner..
Thank you for this :) DSM forums still blessing people years later, haha.
9. Sensor de detonación
Carcasa hembra de 2 posiciones sellada serie KUM 090(NMWP) [gris] {PBT} [PB625-02127]: New United Race Tech, New United Race Tech
Soporte hembra de 2 posiciones de la serie sellada KUM 090(NMWP) [naranja] {PBT} [PB875-02900]: New United Race Tech, New United Race Tech
¿Dónde está? Where is this connection located and what is it for?
The connector in the post you quoted is for the knock sensor (which threads into the backside of the engine block). The wiring connector is up higher, near the throttle body (back center area of the engine bay).
Just performing some CPR on this thread to keep it alive haha!
Two questions:
1. Is there a new place to go to order the connectors both male and female? I know that there are links in the post but it seems that they are now dead. I am hoping to find a new spot to order these plugs to make my own harness/replace old, broken plugs.
2. Is there a write up like this one for the other harnesses? I am in the middle of doing my interior and although I have the electrical manual, it is very confusing compared to something like this and I have a couple of plugs that don't seem to be correct, but I want to be sure before I pull everything out and swap to a new harness.
Two questions:
Places such as Mouser, Digikey, and Newark may have them, the biggest thing is knowing the pin count and spacing (i.e. 2.54mm). These connectors are out there, fewer places carry them than before as you see from dead links. But the places mentioned above may have them or you can try and replace them if they are free floating (i.e. not to a module).
There are other places such as Wirecare and Waytek Wire but they will most likely not have OEM and will be other weather pack styles (such as Metripak 150).
Where do these wires go to? I cut them and I didnt realize 4 wires were the same color. Do you know what color wire and pin goes where?
I think the only wires that are the same color or the black one which would be ground (possibly sensor ground). If the other wires look like the same color, clean them real good and double check again.
  • For sale 2g 2GA Turbo/Automatic Engine Harness
    2GA Turbo/Automatic Engine Harness $225 + shipping & paypal fees* all plugs are complete and...
  • For sale 4G63 6 Bolt Oil Pump Pickup ( great condition )
    6 Bolt Oil Pump Pickup $65 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G OEM BOV Hose ( great condition )
    2G OEM BOV Hose $25 + shipping & paypal fees* great conditionYou must be registered to see...
  • For sale 1g 1G OEM BOV & Vader Cap
    OEM 1G BOV & Vader Cap $45 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 1g LSD 4 Bolt Rear Differential
    1G LSD 4 Bolt Rear Differential $250 + shipping & paypal feesYou must be registered to see...
