2G 2G DSM cluster light bulbs
What size are the cluster lights for the 2G dsm , gst .. yes I’ve looked through the forums but I just don’t seem to get a straight simple answer . What size are the twist in bulbs for the 2G cluster … I want to change the orange to another color
If the DSM clusters are like the 3s clusters that I know, simply changing the bulb will not change the color. The cluster itself is tinted orange.
Searching for "Gauge cluster bulb" I found this article which has your answer, a 2773
As @stealthee stated though there is a lot of work that goes into changing the look of your gauge cluster with just LED bulbs. There is a guy that makes some really cool ones for 2g though if you are interested. I also restumbled across him while searching and I bet you did too, but here is a link just in case.
This is the article which describes how to redo the cluster lighting using the method I mentioned above
Good luck!
Yeah I think youre Right the bulb itself won’t change the color /: I guess I’ll just leave them like that , since I already have some wires for gauges and the carbon fiber bezel . I was hoping to be able to do it without messing with any wires
