2G Clutch wire install for stutter box
AWD_DSM08
72
Feb 3, 2008
chicago, Illinois
Well for some reason I cant get on the key driver forum where I bought my chip. The instructions are not to clear anyone have anything saved or could show me some directions for this? Thanks
If this is for your '95, you don't have to wire anything up. The vehicle speed sensor, not the clutch switch, kills the stutterbox. I have a Keydiver chip in my '96 and that's all it took...plug it in, set it to the rpm's I wanted, and go.
Okay yes it is a 95 so all I need to do it install the chip and its good to go? mine is a keydriver chip but it came with a 3 wire deal to hook up to pin 91
I just read a couple of posts on Jeff's forum and he reiterates that there is no clutch wire mod for his 2g stutterbox.
PM sent.
Edit: To be safe, just send him an email and ask what's going on. Maybe he sent you a 1g eprom by mistake.
Double Edit: His 2g ecu's use a wire to pin 91 for NLTS, so you must have that option, too. That IS a clutchswitch operated function, so it will have to be wired in.
correct that is what im installing I guess its three wires MY access is not up on that forum of his. IS there a write up I have a yellow and black on one side and white on the other any help id be greatful for I guess hes on a trip for work. So Im kind of in the dark and need to get it wireed and done
