2G 2g carrier bearing availability/options
Adam
129
122
Jan 6, 2017
Silver Springs, Nevada
Looks like my rear carrier bearing is on its way out.
Extreme psi lists out of stock. Oreilys doesn't even list one.
What are the options now days?
JXB stuff looks nice but they're just shells made to fit existing bearings.
1g bearings look like they could work if you bent the mounts flat or used the JXB shells but I have no idea if the bearing dimensions are the same.
Any bolt in options?
Any custom options?
I've made rear hangers before when doing awd swaps and am not opposed to making a different mount setup if there's a bearing for a different vehicle that fits the shaft but bolts up differently.
Thanks
While not 2G (they are in development still) the 1G is done and options available. 1G being easier to do vs the 2G. Here is a link to the 1G option to view at least. But hopefully not long the 2G will have a rebuild kit the same as the 1G now has. Just maybe differently designed but end result will be close and rebuildable. https://www.dsmtuners.com/threads/fiba-motorsport-product-updates-1g-2g-evo.546622/post-153957299
FYI the front and rear of the 2G is now 1 item. They gone away from the shielded design. You likely will never find the differing product again
