2G Cam size
gsx rated98
536
Mar 16, 2004
LaPlata, Maryland
What are the stock sizes for the intake and exhaust cams on a 2G GSX 98, also the Cam Gears. What im wondering is will the EVO cams and gears fit in the 2G. Im like 90% sure they will since there both 7bolt 4g63s, but just want someone to confirm. Also, is there a size diffenece between the 2G and Evo Cams? Thanks
Jerry
stock evo8 cams are advertised duration of the intake and exahsut cams is :
intake exhaust
225deg lobe 220deg
238deg valve 234deg
hope this helps
more info found. Evo cams will not work in 2g. Because the lift on the intake is 10.8 which is too large. The exhaust was 10.3mm. The other reason they wouldnt' work is the EVO8 is mounted backwards compared to the 2gs. Meaning the cams in essense would be 'backwards.'
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
