2G 2g awd fuel tank wiring
Bedicine
542
189
Jan 3, 2022
Toronto, ON, Canada
Hello,
Hoping someone could shed some light on a 2g AWD fuel tank and wiring. The gas tank and car is a 95 AWD, where as the wiring harness I’m using is from a 97 AWD. Fuel pump wire connects no problem but when I go to plug in the drivers side connector it is an 8 pin vs the 6 pin.
Am I able to rewire this or is it easier to get a harness off a 97 AWD tank?
Pictures show connectors from 95 and 97.
Is my only option to get a 97-99 sending unit/ harness for the tank to match the car harness?
I was able to get the sending unit harness from a 97-99 which fixed the connection to the sending unit however when I go to plug it in on the drivers side I’ve run into another issue.
Current connector in car is 4 pin but the wiring going to it was only 2 wire. The harness I got has 4 wire but wiring colors look different and I’m not sure which two the wires hanging out would get plugged in to.
2nd pic is 97 harness
3rd pic is the harness that came with the car 95 TSI
Any help would be appreciated. Thanks
Car is a 1995, I believe the tank is from a 95 but the guy I purchased it off had that and a 97 so I have an assortment of parts.
The harness is from a 97 I believe. Is there anyway to verify?
There might be a way to verify if Mitsubishi changed wire colors for any part of it. I've had mostly 95-96 models so I can look when I get home to see if I have a spare harness pigtail.
I believe the tank in my Galant is a 97+? It was a bare tank from Millers and finding the pump/siphon housing was kind of difficult for me. Im currently not home but I’ll double check what exactly I did later tonight:tomorrow. My setup work besides the Fuel level gauge because I have the wrong sensors
thanks everyone. Just trying to figure out this pump issue, it stumped me even more when i took off the connector and it only had two wires but the pump had a spot for 4 wires.
These are from the 1996 FSM. Note that E-09, the rear wiring harness and fuel wiring harness combination, is 8-pin (2 rows of 4) for a FWD and 6-pin (2 rows of 3) for an AWD. I would assume this to be very similar to the 1995 model, other than the fuel pump relay.
What these show, plus a little additional information:
E-09, FWD
[XX]
[01][02][03][04]
[05][06][07][08]​
Pin 1 - Yellow with blue stripe, intermediate connector for ABS right rear sensor (pin 1)
Pin 2 - Gray with blue stripe, intermediate connector for ABS right rear sensor (pin 2)
Pin 3 - Black, intermediate connector between pin 2 of connector E-37 and ground for fuel gauge unit
Pin 4 - Yellow, intermediate connector between pin 3 of connector E-37 and, ultimately, pin 3 of C-06 for fuel gauge unit
Pin 5 - Yellow with red stripe, intermediate connector for ABS left rear sensor (pin 1)
Pin 6 - Gray with red stripe, intermediate connector for ABS left rear sensor (pin 2)
Pin 7 - Yellow with blue stripe, intermediate connector between pin 1 of connector E-37 (fuel gauge unit) and pin 15 of connector C-06 for low fuel warning light
Pin 8 - none
E-09, AWD
[XX]
[01][02][03]
[04][05][06]​
Pin 3 - Yellow with black stripe, intermediate connector between pin 1 of connector E-39 (sub-fuel gauge unit) and pin 5 of connector E-36 (fuel gauge unit)
Pin 4 - Yellow with red stripe, intermediate connector for ABS left rear sensor (pin 1)
Pin 5 - Gray with red stripe, intermediate connector for ABS left rear sensor (pin 2)
Pin 6 - Yellow, intermediate connector between pin 2 of connector E-39 and, ultimately, pin 3 of C-06 for fuel gauge unit
E-36, FWD
[XX]
[01][02]​
Pin 1 - Black with blue stripe, fuel pump (+), to pin 1 of FP relay
Pin 2 - Black, fuel pump (-) to ground
E-36, AWD
[XX]
[01][02]
[03][04]
[05][06]​
Pin 1 - Black, fuel pump (-) to ground
Pin 2 - Black with blue stripe, fuel pump (+), to pin 1 of FP relay
Pin 3 - Yellow with blue stripe, ultimately to pin 15 of connector C-06 for low fuel level warning light, thru pin 15 of connector B-71 and pin 18 of connector C-24
Pin 4 - None
Pin 5 - Yellow with black stripe, to pin 1 of connector E-39 thru pin 3 of connector E-09
Pin 6 - Black, ground for fuel level gauge unit
E-37 (FWD ONLY)
[XX]
[01][02][03]​
Pin 1 - Yellow with blue stripe, ultimately to pin 15 of connector C-06 for low fuel level warning light, thru pin 7 of connector E-09, pin 15 of connector B-71, and pin 18 of connector C-24
Pin 2 - Black, ground for fuel level gauge, thru pin 3 of connector E-09
Pin 3 - Yellow, ultimately to pin 3 of C-06 for fuel gauge unit, thru pin 4 of connector E-09, pin 5 of connector B-71, and pin 6 of connector C-24.
E-39 (AWD ONLY)
[XX]
[01][02]
[03][04]
notch ^​
Pin 1 - Yellow with black stripe, to pin 5 of connector E-36, thru pin 3 of connector E-09
Pin 2 - Yellow, ultimately to pin 3 of connector C-06 for fuel gauge unit, thru pin 6 of connector E-09, pin 5 of connector B-71, and pin 6 of connector C-24
Pin 3 - none
Pin 4 - none
These are from the 1997 FSM. Note that E-09 is an 8-pin (2 rows of 4) connector for all models.
E-09, FWD -- same as 1996
[XX]
[01][02][03][04]
[05][06][07][08]​
Pin 8 - none
E-09, AWD
[XX]
[01][02][03][04]
[05][06][07][08]​
Pin 3 - Yellow with black stripe, intermediate connector between pin 1 of connector E-39 for sub-fuel gauge unit and pin 5 of connector E-59 for fuel gauge unit
Pin 4 - Yellow with blue stripe, intermediate connector between pin 3 of connector E-39 for sub-fuel gauge unit and pin 15 of C-06 for fuel level warning light
Pin 7 - Yellow, intermediate connector between pin 2 of connector E-39 (sub-fuel gauge unit) and pin 3 of connector C-06 for fuel gauge unit
Pin 8 - Yellow with black stripe, intermediate connector between pin 4 of connector E-39 (sub-fuel gauge unit) and pin 3 of connector E-59 (fuel gauge unit)
E-36, FWD - Fuel Pump Connector
[XX]
[01][02]​
Pin 1 - Black with blue stripe, fuel pump (+) power
E-37, FWD only - Fuel Gauge Unit Connector
[XX]
[01][02][03]​
Pin 1 - Yellow with blue stripe, to pin 15 of connector C-06 for fuel level warning light
Pin 2 - Black, ground for fuel gauge unit
Pin 3 - Yellow, to pin 3 of connector C-06 for fuel level gauge
E-39, AWD only - Sub-Fuel Gauge Unit
[XX]
[01][02]
[03][04]
notch ^​
Pin 1 - Yellow with black stripe, runs through pin 3 of connector E-09 and then to pin 5 of connector E-59 for the fuel gauge unit.
Pin 2 - Yellow, to pin 3 of connector C-06 for fuel gauge
Pin 3 - Yellow with blue stripe, through pin 4 of connector E-09 to pin 15 of connector C-06 for low fuel warning light
Pin 4 - Yellow with black, to pin 3 of connector E-59 for fuel gauge level sending unit through pin 8 of connector E-09
E-59, AWD only
[XX]
[01][02]
[03][04]
[05][06]​
Pin 1 - Black, ground (-) for fuel pump
Pin 2 - Black with blue stripe, fuel pump (+) power
Pin 3 - Yellow with black, to pin 4 of connector E-39 (sub-fuel gauge unit) through pin 8 of connector E-09
Pin 4 - none
Pin 5 - Yellow with black, to pin 1 of connector E-39 (sub-fuel gauge unit) through pin 3 of connector E-09
Pin 6 - Black, ground for fuel gauge unit (E-59) and sub fuel gauge unit (E-39)
[XX]
[01][02][03][04]
[05][06][07][08]​
Pin 8 - none
E-09, AWD
[XX]
[01][02][03][04]
[05][06][07][08]​
[XX]
[01][02]​
[XX]
[01][02][03]​
[XX]
[01][02]
[03][04]
notch ^​
E-59, AWD only
[XX]
[01][02]
[03][04]
[05][06]​
Pin 4 - none
Sorry, somehow didn't see you posted this. Super helpful. going to try this over the weekend :)
[XX]
[01][02][03][04]
[05][06][07][08]​
Pin 8 - none
E-09, AWD
[XX]
[01][02][03][04]
[05][06][07][08]​
[XX]
[01][02]​
[XX]
[01][02][03]​
[XX]
[01][02]
[03][04]
notch ^​
E-59, AWD only
[XX]
[01][02]
[03][04]
[05][06]​
Pin 4 - none
Hey man quick question, for E-59, AWD only
Pin 3 you have labeled as Yellow/black. Isn't it yellow/blue? Just making sure i have it right so I can finish wiring my swap
