2G Gst fuel hanger in GSX wiring sender/pump
my98gsx
Supporting VIP
794
290
Aug 14, 2005
Wappingers, New York
I recently purchased a Vamos design fuel tank which allows for the use of a gst hanger if an oem pump and level sender would like to be used (which I want to do). I have been searching for wiring but have been unable to find anyone who has done this. The pump is not really and issue to me since it is only a power and a ground and would be easily determined. The main concern/issue I am having would be the level sender. I want the stock gauge to work, and am unaware how to use a GST hanger in a GSX. If anyone has any information I would greatly appreciate it. Thanks
so the FWD unit uses connector E-37
pin 1 (yellow/blue) low fuel light
pin 2 (black) ground
pin 3 (yellow) fuel gauge
i would splice it in to the wires off connector E-09
pin 4 (yellow/blue)
pin 7 (yellow)
you can source the ground from the AWD gauge unit connector
pin 6 (Black)
or just run your own ground.
i think thats as simple as i can make it. i hope it helps cause it took me at least the last 3 hours to slap that pic together.
its almost 6am so im too tired to get much into
FWD spec is
F:-full (float at highest point)
E:=empty (lowest point)
with 5.25" of travel between
