2G AWD drive gear (pinion) tooth count
raptoranderson
195
22
Sep 24, 2015
Graham, North Carolina
I am doing some of the legwork and research into making a taller fifth gear for a 2G and I need to know what the tooth count on the pinion coming from the engine into the gearbox is.
I've got all of the ratios of gears 1st-5th and I have the final drive ratio, so if I knew the tooth count on the drive gear I could then back-calculate to figure out the number of teeth on each of the individual gears.
Does anyone know what the tooth count on the pinion that outputs drive to the transmission is?
I've got all the manuals to the car. I'm pretty sure it is in there. If i forget, remind me and I will load them on a flash drive and bring them in.
