2g Auto won't shift into 4th after battery swap
jdlohr
Jul 16, 2012
Bloomington, Minnesota
Yesterday my battery died (left a light on). I was able to get it running again by searching through this site. Blew the 100A Alt fuse as well.
But my car won't shift into 4th. It's an auto and didn't have any problems before my battery drained. I dug through quite a few threads such as: Automatic won't shift into 4th gear help
Is it possible that my SAFCII reset or is messing this up? Also of note, my radio doesn't work and isn't getting power (gauges and cabin lights work. obviously car starts now). I'll check my fuses again
Yes, I checked the OD switch
-- Update
Checked the under dash fuse box (#15): 2g Turbo under dash fush box diagram recommended in this thread: [RESOLVED] Auto Trans, says in 3rd gear?
If anyone else has advice, it's much appreciated
Well the bat. dieing will reset the Safc, no clue what that would do to the trans. Id say it has to be a bad fuse or relay somewhere. Idk if OD has a relay but some searching could tell you.
