2g, 5spd, where too connect coolant lines..
stiggity99
231
4
Mar 31, 2011
York Haven, Pennsylvania
I've done some searching, and still cant seem to find an answer, it seems once someone asks a certain question, the answers stop right there. I have (2) fittings on my throttle-body, and i know there for the FIAV in the TB. Then i have (1) fitting pointing straight up, and it's attached to the water-tube that runs from the water block to the water pump. Then finally i have (1) fitting attached to the water bloack... can anyone tell me how to connect these fittings, so i have coolant flowing in the right direction... thank's alot.
--Steve
Ed/19eclipse90:
thank both of your for the replies. I decided not to loop the FIAV, and i ran my lines, like the prior reply.i drove to the local Mitsu dealer, ane looked in there files, and found the routing diagram.. i appreciate the help.
--Steve
